    Aug 2009
    nottingham
    38
    240v 60hz compressor's on 240v 50hz supply
    Hi All
    Can anyone confirm, if you fitted an 60hz compressor on 50hz supply, would the 60hz compressor run slower, hotter with less capacity than the identical model if it was 240v 50hz?.
    And while im asking would this be the case vice-versa??
    Thanks for taking the time to read this.
    All the best!!!!!!!
    70
    10,650
    52
    Re: 240v 60hz compressor's on 240v 50hz supply
    Here's some reading for you from a quick forum search...
    http://www.refrigeration-engineer.co...a-60HZ-circuit
    Sep 2003
    ISRAEL
    66
    4,173
    40
    Difference between 60hz and 50hz is 17%, it affects speed and capacity.
    Watt draw will remain almost the same.
    Aug 2009
    nottingham
    38
    thanks guys!!!!!!!!
