Results 1 to 17 of 17
    Mar 2018
    Glasgow
    Help with C&G F-Gas
    Hey guy's just in the off the chance anyone could point me in the right direction for the above course notes/exam questions.
    Would be appreciated.
    4,703
    Re: Help with C&G F-Gas
    Hi Johnny
    Welcome to the forum.
    Try the link below.
    http://www.acr-news.com/service-and-...the-f-gas-test -----
    Sorry That link does not appear to work.
    Copy and Google it and you should get the correct link.
    Or just type F gas questions and look for the corresponding link.
    It's got some good questions related to F gas.
    A lot of us used it historically as a bench mark!
    Good Luck Grizzly
    Mar 2018
    Glasgow
    Doesn't work mate?
    Mar 2018
    Glasgow
    Thanks for the welcome
    Mar 2018
    Glasgow
    Found it mate are they old questions?
    4,703
    Old as a fridge system. Yes but still totally relevant.
    Still based of the same principals!
    Unless some of our more knowledgeable trainers can enlighten further.
    F gas is still F gas.
    Its a good start anyways!
    Mar 2018
    Glasgow
    Definitely mate thanks
    Mar 2018
    Glasgow
    Can anyone else help?
    11,025
    The courses haven't changed so the answers are much the same.
    Mar 2018
    Glasgow
    Hey Brian I have never done it that's how I'm looking for some help!!
    11,025
    Fair enough, as most courses teach the same thing I would look into the costs involved from the various teaching centres.
    As Grizzly has stated elsewhere, check how long the pass ticket lasts for. The lifetime tickets only last until someone changes the fgas regulations.
    May 2012
    59
    1,528
    You will be tested on both practical and theoretical.
    Practically you need to be able to fit gauges, analyse the system
    Then remove all the refrigerant, find and repair a simulated leak
    (including a brazed joint). Then you pressure test the system to the
    correct standards, vac it out correctly and then recharge with the
    correct weight of refrigerant.
    Finally remove the gauges, all this without losing too much refrigerant
    and without contaminating it.
    Theoretical, you will need to know the science behind heat transfer and
    energy calculations, know how basic refrigeration systems work including
    the four main components used.
    Evaporators
    Compressors
    Condensers
    Metering devices
    You will need to be able to answer 40 questions (C&G online closed book) and
    (BESA is open book but you will have to get 100% correct).
    Theoretical includes system operation and scenario problems like if filters block
    what happens, if a condenser is cleaned what happens to the Work Done or if
    a cold room door is left open what will happen to the indirect emisions???
    Quite a few "if this does that, how will it effect those" type questions.
    Rob
    Apr 2008
    Southampton, England
    49
    1,023
    Think I'm referring to your other thread but anyway, is it too late to think about doing the NVQ instead and looking for a trainee job. It'll work out cheaper.
    A lot of the electrical stuff I doubt you'll need unless you can sign off a power supply install that'll be about it and most firm will get an electrician to do that anyhow.
    When it comes to electrical fault finding for refrigeration panels I'm not sure there's even a course for that. More a case of figuring stuff out from wiring diagrams or the spaghetti of wiring the last bloke left and building up your own experience from there.
    Either way good luck!
    Andy.
    Mar 2018
    Glasgow
    Yes mate I'm planning that but need to be employed before I can apply for it
    Apr 2008
    49
    1,023
    Ah, cool. Back when I started college, 2006, we could start on the technical certificate, once employed you can then get the portfolio of work completed and signed off and get the NVQ, that was the only difference between the two. Is that still the case?
    Mar 2018
    Glasgow
    Not 100% about that mate
    4,703
    Quote Originally Posted by Tayters View Post
    Andy.
    J&E Hall Training used to do an advanced Electrical Fault finding Course, which was geared for fridgies!
    (Not sure as to whether others still do so)
    I know Tech Train also did.
    But I am not sure they are still in existence?
    There used to be a CITB Course if I remember correctly.
