Results 1 to 26 of 26
Threaded View
03-04-2018, 11:13 AM #16
Re: Calculating Reheat Capacity - For Humidity Control
Good thought. The reason is again high RH. The space needs to be pressurized, hence I need some percentage of fresh air supply through out the year. This fresh air will causes varying RH (sometimes very high during winter and rain). To control these, and to meet the design RH set point of 50%, I need the chillers to be functional through out. . .
