Thread: Vrv iv
    Nov 2005
    wales
    66
    Vrv iv
    Anyone had experience with multiple compressor failures on same system & did you find a cause? Checked the usual - refrigerant quantity, oil for acid, oil return. Starting to run out of ideas.. Not getting any error codes until the compressor, inverter pcb and noise filter pcb have all failed.
    Oct 2001
    Nottingham UK
    5,668
    Re: Vrv iv
    All our VRV 4 installs are still running sweet - no problems at all
    Aug 2007
    Russia
    138
    21
    Re: Vrv iv
    Have you cut open any of the failure compressors?
