    Mar 2016
    IRAN
    157
    3
    Cleaninig evaporative condenser
    Dear Friends,
    For cleaning evaporative condenser, One of the best way is using gas/petrol and fire. You can see photos before and after cleaning in attachment.
    If you have any other better experience, I will be thankful if you share this with me.
    Sincerely yours.
    2,565
    28
    Re: Cleaninig evaporative condenser
    Interesting results, but in a lot of cases would not be allowed.
    Labour to remove & re-install would be very high, as well as cranage.
    If monitored & operated with water treatment it should never get that bad
    Have a client that has special stainless steel looking cylinder in sump of cooling tower
    that prevents calcium & scale build up & reduced water bleed off rate.
    Only add biocide.
    Link below may be similar product, will have to find out.
    http://www.merusonline.com/coolingwa...yAAEgJGNvD_BwE
    70
    10,602
    52
    First rule :- Read and follow maintenance instructions.
