    Nov 2007
    Australia
    64
    Bitzer 6G compressor
    I have a Bitzer 6G compressor with unloaders on 2 heads. My suction pressure is 2.5 Bar but when the compressor is fully loaded the crankcase pressure rises to 6 Bar.
    When unloading the right hand bank of cylinders the crankcase pressure comes down to suction pressure.
    To me it looks like there is a crack in one of the pistons in that bank, or the piston rings are broken.
    Has anyone had issues like this with Bitzer compressors?..
    Jun 2011
    Australia
    44
    336
    Re: Bitzer 6G compressor
    Hi Peter,
    https://www.bitzer.de/shared_media/d...n/kb-520-6.pdf
    Has it functioned correctly previously?
    Possible curve ball (Check from document above, Page 13) Head Cover Markings “SU” or “CR”
    SU is Start Unload
    CR is Capacity Regulation
    Mismatch of these could result in some wacky operation
    Happy tinkering
    Feb 2009
    telford
    2,090
    33
    Get a gasket set and take the heads off that's the only advice I can give,for the price it's worth having a look inside.
    3,362
    Quote Originally Posted by HVACRsaurus View Post
    Hi Peter,
    SU is Start Unload
    Happy tinkering
    Hey don’t you guys work for same company
