    Mar 2012
    Porto
    49
    Question McQuay HSW3122 Screw Compressor Maitenance
    Hi everybody.
    I need to do some maintenence on a HSW3122 McQuay Screw compressor.
    Where can i get info with torque tightness values in PDF format.
    Thank you in advance!!!
    495
    Re: McQuay HSW3122 Screw Compressor Maitenance
    Which part of the compressor are you tightening
    Mar 2012
    Porto
    49
    Hi GAHZ,
    It is a change oil and filter maintenance. So I need filter cover, oil drain and filler plugs.
    Thank you!!!
    495
    Hi oil filter cover 60nm
    13 litres of ester 68 oil
    Vac the oil in from drain valve ,Which is 1/2 flare
    Mar 2012
    Porto
    49
    Thank you very much GHAZ.
    I still need oil filler plug tightning torque to retight and eliminate a very small leak and oil residue.
    Can you help me with that?
    Thanks again!!! (Y)
Tags for this Thread
