    Nov 2017
    South Africa
    4
    Stal S83 slide Pot
    Hi All
    i have come across a Stal S83 which has a faulty slide pot, i have received a new version of the slide pot but without any information of the conversion or wiring connections. i hope someone will be able to help with this information.
    thanks
    3,363
    Re: Stal S83 slide Pot
    A.King,
    Usually supplier like Johnson controls can supply instructions if asked.
    Is it look the same as existing, as there was an older different style which then would require an upgrade kit or older type sensor supplied instead.
    Best to give them serial number of compressor when ordering, as these parts very expensive.
    This is latest I think
    http://www.hbproducts.dk/images/cert...ual-022-UK.pdf
    Nov 2017
    South Africa
    4
    Thanks Ranger
    this information is a big help
    Jul 2007
    Czech
    61
    374
    Hello King,
    I'll add Ranger1, big attachment, I'm sending an email.
    Josef.
