    Sep 2017
    Canada
    3
    TK SB210 - Codes - 11,13,203,03
    We're having a lot of trouble with this reefer. We keep having Codes - 11,13,203,03 come up. We've changed the return air sensor. Tried a different ECM. Sent the unit to the dealer. No success, keeps up with these codes and runs with the amber light on at a sceptical temperature. Any suggestions would be appreciated.
    Aug 2011
    Canada
    160
    9
    Re: TK SB210 - Codes - 11,13,203,03
    Quote Originally Posted by JBoston View Post
    Did you change one return air sensor or both? Unless one of the sensors is way out it's impossible to tell which one is faulty so I usually change both the control and display sensors. Can you get a download and see what the temperatures were reading when it set the codes? There is also a kit from TK that straps the two sensors together.
Tags for this Thread
