    Dec 2008
    77
    137
    Zoin serveover display counter
    Dont know if anyone has had the same problem but intermittently they system blocks causing the capillary to frost back passed the filter to the condenser which causes the bottom couple of rows on the condenser to sweat. It has recently had a new compressor and filter drier,evacuated and recharged. It can be switched off for a while then switched back on and it works for a while. Any ideas guys.
    11,025
    Re: Zoin serveover display counter
    Refrigerant type?
    Oil type?
    Why was the compressor changed?
    Oil acid level checked at compressor change?
    Dec 2008
    77
    137
    Hi Brian. R134a. Compressor was noisy. Oil poe. No burnout.oil ok.
    5,668
    R134a is known to block capillaries due to oil floccing
