Results 1 to 2 of 2
    Apr 2016
    Lietuva
    26
    4
    Cooper and hunter temperature sensor setting
    Hello guys (girls),
    AC model: cooper and hunter CH-ID18NK4
    Controller model: wired XK60
    I would like to change the sensor setting on my ac. By default temperature is measured at inlet, but i need to set it to measure room temperature at the controller, is it even possible? In older generations (they have buttons on the right side of screen) it was possible, but now i can't find any info on owners manual. This is the controller with two rows of buttons.
    Oct 2001
    Nottingham UK
    5,127
    42
    Re: Cooper and hunter temperature sensor setting
    Follow this link and select the 'cassette' type.
    scroll down to the 'debug' instructions and it explains how to change the sensor position from return air to controller
    http://www.cooperandhunter.org/page.php?id=9
    I'm back on the Pale
Tags for this Thread
