    Jul 2014
    Northern ireland
    8
    Thermo King sl200e just keeps cooling
    As per title, I have an sl200e set to run on continuous at +3c. It just keeps cooling with no alarms, ever seen this before, have any of you guys experienced this? Cheers!
    69
    10,500
    Re: Thermo King sl200e just keeps cooling
    Little clues help the answers, like..
    What temperature is the space when it is still running?
    Jul 2014
    Northern ireland
    8
    Fairly sure it’s controlled by the DAS sensor, have yet to do a download as laptop is at the workshop and I’m on site. The unit was set for +3 and I switched it off at -17 with no alarms. Problem is it’s been a long time from I’ve replaced sensors and can’t for the life of me figure out how to change the sensor grade from 7h to 6h. It’s a thermoguard V1b controller, thanks for helping!
    Jul 2014
    Northern ireland
    8
    Unit is now up and running, sensor was to blame, if I’m correct this unit doesn’t have a modulation valve, therefore grading not nessessary. This still doesn’t explain why I can’t get into guarded access! Set point at zero, scroll back to set point, hold button, press up and down together and no joy, maybe I’m doing something wrong but that’s all I can find on our workshop manual
    Feb 2009
    telford
    1,981
    26
    Google,how to enter guarded access on thermo king the instructions are there.
