Results 1 to 13 of 13
    Aug 2016
    Uk
    31
    21
    50 ac units, decommission and recomission
    Evening all
    I have been asked to quote to decommission and recomission 50 split units. 10 are r22 so i will give them a price for r453a.... i have read some where that a substitute refrigeranf is only good for a short term solution as it puts the r22 unit under more strain and decreases the life span of the compressor.... is this correct?.
    Also what would you all charge to do each unit? ...
    Feb 2006
    Hampshire
    61
    13
    Re: 50 ac units, decommission and recomission
    I've used mo99 and 417a number of times and seen nothing negative, or breakdowns that I'd attribute to it. Don't know about 453a - not used it.
    As to what someone would charge for the job, hard to say without seeing the site / logistics of the job.
    Aug 2016
    Uk
    31
    21
    ahhh thats good to hear. Well basically its literally a big roof that has to be redone which is why im moving the condensers. They will be moved to one side of roof then re fitted at end.
    So
    Reclaim refrigerant/pump down where possible
    lock off electrical isolator
    Disconnect cables and pipe
    Move unit
    Come back 2 weeks later
    Reconnect the wires and pipe
    Pressure test for 1 hour
    Vac system
    Charge system
    Commission systems.
    I have a rough idea in my head but im not only one quoting for job so wanna make sure im not miles out
    Feb 2006
    Hampshire
    61
    13
    Is it 50x single splits?
    Sep 2010
    70
    209
    10
    I'm sure you have it covered as you are talking about drop-ins but, no pump downs on R22 units, gas swap only.
    Brian, retired in Devon.
    Oct 2001
    Nottingham UK
    5,123
    42
    Make sure that all 50 units are in full working order BEFORE you de-commission. If you don't and you find that some don't work properly when you re-commission, you will struggle to convince them that it was not your fault and you may end up having to repair at your own cost!!!
    I'm back on the Pale
    Aug 2016
    Uk
    31
    21
    Ahhhh gd point there mate, didnt think about that. Last ting i need lol
    Aug 2016
    Uk
    31
    21
    Yh, i aint looking to bodge things. Doit properly is my way, best way to build a gd repuation
    Aug 2016
    Uk
    31
    21
    Quote Originally Posted by terminator View Post
    Sorry, yes 50 single splits.
    Dec 2008
    511
    Don't forget to allow for the cost of the recovery cylinders and the possible cost of the destruction of the R22. Get the latest price for the drop-in refrigerant, as they are constantly changing.
    44
    3,799
    38
    Price it for what you think it will cost and how much you want to make. Don't lose any sleep if you don't get the job, the cheaper guy may be losing money on it....
    Feb 2009
    telford
    2,059
    27
    Dont price it low,price it high you can always come down but never go up!
    Sep 2010
    70
    209
    10
    Don't forget to allow for the pipework damage and mangled cables that you will find after the roofing contractor has finished with them.
    Mention it in your quote as in "assuming that all disconnected pipes and cables are as left prior to the roofing works" etc. Take lots of dated photos.
