Thread: Increase of gas / pipe
01-06-2006, 05:57 PM #1
Doe's anyone know a calculation for increasing gas quanity when pipe work is lenghtened, The pipes are 1/4 & 1/2" & were extended by 2.5 metres, The gas is 407c.
Thanks Dave.
01-06-2006, 06:42 PM #2
Re: Increase of gas / pipe
Can you tell us what unit it is on. On an a/c system usually it will say on the data plate what the standard charge is and what pipe run it will go up to and then it will also give you a weight of gas per meter extra if you go over that run.
Fatboy
01-06-2006, 06:48 PM #3
Hi Raymond,
The unit is a Northstar & requires 1.56g of gas for a 4 metre run but doe's not state what is required per extra metre.
Dave.
Single room a/c - long pipe run?
By electro in forum Air ConditioningReplies: 7Last Post: 07-08-2006, 09:49 PM -
pipe sizeing tool
By Latte in forum Tools and CalculatorsReplies: 5Last Post: 10-12-2003, 11:32 PM -
How many small strands needed to equal pipe pressure drop?
By DaBit in forum FundamentalsReplies: 17Last Post: 25-08-2003, 09:56 PM -
Pipe sizes
By benncool in forum Chit Chat & Service StoriesReplies: 10Last Post: 08-07-2003, 10:58 PM
