Thread: 60Hz Copeland scroll compressor
31-05-2006, 03:45 AM #1
Dear Sirs
I need 60Hz Copeland scroll compressor for we'll export chiller to America. Here is only 50Hz compressor in our place. Hope you can help to find the catalogue or useful links thanks
regards
LC
31-05-2006, 11:08 AM #2
Re: 60Hz Copeland scroll compressor
Dear LC,
To my knowlegde Copeland scroll compressors are 50 and 60Hz. Look at the motor codes in attachment.
Best regards.
Bruno
02-06-2006, 06:43 AM #3
Hi Bruno
Thanks for your kind help!
50Hz and 60Hz compressor is only different in motor type?
rgds
LCI hear...I forget;I see...I remember;I do...I understand
02-06-2006, 09:41 AM #4
For 50 and 60 Hz you can use the same compressor.
For example: a ZR90K3E-TFD can run on
50Hz: 380/420 V +/-10 % (so between 342 and 462 V)
and on
60Hz : 460V +/-10% (so between 414V and 506V)
Best regards.
Bruno
05-06-2006, 01:23 AM #5
thanks
05-06-2006, 09:08 PM #6
Indeed Lc_shi, you're capacity will increase with +/- 20%
You got my mail?It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
50HZ compressor on a 60HZ circuit
By dan wong in forum Technical SpeculationsReplies: 28Last Post: 13-06-2009, 05:52 PM -
Compressor pumping efficiency
By shogun7 in forum FundamentalsReplies: 0Last Post: 25-02-2004, 10:50 PM -
One Half of a Part Wound Compressor Motor is Burnt
By aygul in forum Trouble ShootingReplies: 2Last Post: 25-08-2003, 11:11 AM -
Compressor failure...... cause
By herefishy in forum Technical SpeculationsReplies: 8Last Post: 06-12-2002, 12:15 AM -
Starting a compressor, and receiver questions.
By DaBit in forum Technical SpeculationsReplies: 9Last Post: 24-08-2002, 12:37 PM
