Results 1 to 10 of 10
Thread: service manual
    Aug 2017
    ITALY
    10
    service manual
    Hello somebody finds it service manual for fridge hitachi r-s700gru8 thanks
    Feb 2017
    112
    9
    Re: service manual
    Quote Originally Posted by JAMESS View Post
    I have both user manual and service manual if you still want this?
    Aug 2017
    ITALY
    10
    Re: service manual
    Yes i want it service manual I'm looking for information If you want to send it to me email kolosatrov@hotmail.com
    Feb 2017
    112
    9
    Re: service manual
    Will send it to you now, hope it helps you
    Aug 2017
    ITALY
    10
    Re: service manual
    Thank you I looked at the code that shows me My refrigerator does not have much information about the codes The code it displays is f012.
    Feb 2017
    112
    9
    Re: service manual
    the service manual just says that f012 is the fan motor abnormal.
    Whats the actual issue with the unit?
    Aug 2017
    ITALY
    10
    Re: service manual
    In the fan connection I have 14volts dc,the fan is panasonic,The problem I have is that when it's running normally after 30 minutes you get the code f012,What I'm looking for is signal Which the fan gives to motherboard,How many volts should it be to see if the volts sent by the fan are correct,If it is right, then it will go wrong motherboard thanks.
    Feb 2017
    112
    9
    Re: service manual
    fridge or freezer side?
    Aug 2017
    ITALY
    10
    Re: service manual
    frezzer fan problem
    Aug 2017
    ITALY
    10
    Re: service manual
    freezer side
