Thread: fridge freezer
25-05-2006, 10:48 AM #1
fridge freezer
I have a large fridge freezer in my garage and in times of cold weather the freezer will not work. Is there anything I can do??
MPOH
25-05-2006, 03:58 PM #2
Re: fridge freezer
Move it into a warmer room
Low ambient temperature fault.
On combination fridge/freezers (single compressor and a single thermostat connected to the fridge evaporator,) if the room temperature drops below the fridge temperature, the fridge stat stays off and the freezer will defrost.
25-05-2006, 10:53 PM #3
Re: fridge freezer
It has been suggested before, and it works, that you rewire the fridge section lamp so that it comes ON when the door closes.
The lamp will then provide a small amount of heat to warm up the fridge section which normally houses the thermostat.Brian - Newton Abbot, Devon, UK
01-06-2006, 07:42 AM #4
Re: fridge freezer
Something we used to do in the 80's was to wire a resistor across the thermostat (can't remember the value now) so when the stat cut out the resistor warmed up the stat close to the bellows making it cut back in.
fridge warm freezer cold?
By babsnsarah in forum DomesticReplies: 25Last Post: 30-04-2011, 04:24 PM -
zanussi fridge freezer
By johnny-dolla in forum DomesticReplies: 5Last Post: 03-08-2006, 09:27 PM -
Brandt Apollo Upright Fridge Freezer
By marto in forum Trouble ShootingReplies: 4Last Post: 06-04-2006, 09:59 AM -
Help! fridge freezer probs
By Glenreed in forum Trouble ShootingReplies: 2Last Post: 06-01-2006, 11:51 PM -
Freezer not cold enough, Fridge too cold
By barrance in forum CommercialReplies: 4Last Post: 06-12-2001, 07:11 PM
