    Nov 2008
    us
    54
    57
    10
    York millennium ycch163 rotary screw compressor
    I understand the slide valve operation, but I do have a question about when the system is down. On this particular chiller there is no external oil pump to drive the slide back to minimal position for start-up. I can only assume (which I hate to do) that there is an internal spring that forces the slide back to minimal position, or ?? Thanks.
    Jul 2007
    Czech
    55
    322
    12
    Re: York millennium ycch163 rotary screw compressor
    Yes, the spring is forcing unloading.
    Josef.
    Feb 2006
    Hampshire
    59
    12
    What's the compressor? Is it the dxs?
    If you're having load / unload issues, it's not unknown for the springs to break on these and require replacement.
