Results 1 to 9 of 9
    Jul 2017
    Qatar
    38
    3
    Check valve for discharge pipe
    Dear All,
    I heard that when air-cooled condenser is above of compressor, We must use check valve at discharge pipe of compressor.
    Why we should check valve ? for prevent returning liquid on top of valve plate of compressor ? Or it has other reason ?
    If we use "Inverted P trap" at inlet of condenser, It is not enough for prevent liquid migration ?
    Thanks if you help me in this topic.
    With best regards.
    Sep 2010
    70
    209
    11
    Re: Check valve for discharge pipe
    Yes a check valve or inverted trap should be fitted at the condenser inlet.
    This McQuay design guide might be of help to you, see page 15. http://bit.ly/2w4dsHI
    Brian, retired in Devon.
    Jul 2017
    Qatar
    38
    3
    Quote Originally Posted by FaultCode View Post
    Thanks a lot
    Sep 2003
    ISRAEL
    67
    4,197
    40
    Refrigerant migrates to the cold place and to the lower place.
    Check valve before the condenser will stop the liquid in the condenser from migrating to the compressor discharge chamber and rist the discharge valves from braking at start up.
    Mar 2016
    IRAN
    170
    4
    Quote Originally Posted by GENERALCOOL View Post
    Dear All,
    With best regards.
    This photo is your answer
    Sep 2016
    Ecuador
    47
    Hi all,
    Recently we discovered some issues with check valves mounted in the discharge line of a multiple R507 compressor system (6 VSD controlled DMW piston). After an issue in the oil separator we found some inner parts of the valves back in the bottom of the separator and it showed several failed.
    How your dealing normal with preventive maintenance on these types, as it's a bit difficult when they are soldered in the discharge lines
    Thanks your thoughts guys
    Aug 2014
    70
    452
    There is no preventative maintenance for these non return valves apart from selecting the correct valves for the system design.
    Check valves for use with variable speed drives are difficult to select as the gas volume can vary by a large amount.
    When selecting NRV's it is selected against the volume flow that will keep the valve fully open. If the valve is not kept fully open because the volume flow is too low then the piston starts to chatter and bang open and closed causing it to break.
    The NRVH has a heavier return spring and will cause the piston to bang up and down until destruction occurs.
    A better solution would be the NRV with the lighter spring as it needs less flow to lkeep it open. With discharge gas flows frequencies and harmonics can be a disastrous situation .
    With piston compressors if the nrv is not sized correctly the nrv piston will oscillate at the same rate as every piston pulsation say an 8 cylinder compressor running at 1500 rpm running for 1 hour will lead to the nrv piston oscillating 720,000 times an hour . At that rate it won't last for very long, also the Ptfe seat will be smashed to pieces,preventing it from closing tight.
    An Nrv should be a smaller size than its surrounding pipe work so that it creates a small pressure drop helping to keep it in the fully open position and allowing the NRV to safely to its job
    Somerset
    64
    4,624
    41
    Excellent advice Glenn.
    Thanks Grizzly
    Jan 2006
    Croatia
    63
    2,147
    Quote Originally Posted by A.Mortezania View Post
    I know this photo is from AC_Guide_McQuay, but for me a very bad example of refrigerant piping .... in this case discharge line from compressor/s to condenser/s ...
    Discharge pipe should run straight vertical above condenser (without horizontal runs - if possible) and then down to condenser inlet (in this case - two elbows less) and without inverted trap. Just at highest point of discharge pipe (this should be above condenser) we can install NRV-check valve and after that pipe must run with slope to condenser inlet.
    Best regards, Josip
