Thread: big TD chiller issue etc
23-05-2006, 07:16 AM #1
HI sirs
For saving energy,big TD chiller/AHU/Air supplier system is coming up.
# Big TD AHU is said to save pump power for water flow reduction but need bigger air cooling coil;
#Big TD air supplier can save fan power same as above;
#Big TD chiller,i can't see its advantage but i've heard some one researched it.
What do you think about it?
regards
LC
23-05-2006, 05:33 PM #2
Re: big TD chiller issue etc
Hi LC,
Can you suggest what a high TD might be for a chiller?
24-05-2006, 01:31 AM #3
regards
LCI hear...I forget;I see...I remember;I do...I understand
24-05-2006, 07:05 AM #4
Oh, high delta T. I see.
Well been there, done that.
Tha main reason for that is to save money on the pump, but that's an installer or consultant problem. Anything else remains the same.
In order to save money on the coils, a lower delta T, not higher, must be used.
Dunham Bush Chiller Alarm
By Regulator in forum Air ConditioningReplies: 11Last Post: 08-12-2010, 01:42 AM -
DIY aquarium chiller
By BarraCuda in forum Technical DiscussionsReplies: 18Last Post: 06-10-2010, 11:02 PM -
York Screw Chiller How low will it go?????
By bruceboldy in forum Industrial CompressorsReplies: 11Last Post: 10-08-2007, 10:29 PM -
Chiller fault
By iceman007 in forum Trouble ShootingReplies: 9Last Post: 27-06-2006, 06:15 AM -
Chiller
By iceman007 in forum Trouble ShootingReplies: 9Last Post: 08-04-2006, 02:48 PM
