    Jul 2011
    Australia
    1
    Pressfit copper fittings for refrigeration
    Has anyone had any experience with pressfit fittings in refrigeration applications? I've just come across the Conex Banninger range of fittings. I've used these style of fittings on water services.
    http://www.conexbanninger.com/search.php?brands_id=58
    Somerset
    64
    4,581
    Re: Pressfit copper fittings for refrigeration
    Are you a plumber or a salesman!
    There are press-fit applications available, however they are designed for the job.
    Nov 2008
    scunny!
    29
    302
    using them on a new install so far so good
    Sep 2003
    ISRAEL
    66
    4,151
    38
    All refrigeration and AC units pipes are vibrating. some vibrate more and some vibrate less.
    All makes of these kind of fittings use O rings to seal the joint.
    It's only a matter of time till they start leaking.
    hookster's Avatar
    hookster is online now Veteran Poster I am starting to push the Mods: of RE
    Apr 2007
    Hampshire
    438
    26
    Have we not been using o-ring seals on the following:
    shaft seals
    solenoid valve stems
    condenser connections
    valve stems
    sight glasses
    oil pumps
    shraeder valves
    I personally prefer the o-ring seal to the reflok system as the seal on an o-ring is carried out with elastomer compression. The pipe if correctly supported and installed as per manufacture standards will meet all the approvals. Compression jointing has already been in use for fluids and gases for numerous years with great success.
    Nov 2014
    Australia
    the only question i have is possible future gas/oil retrofits, would this shrink the seal like what we have seen with R22 to R407C, therefore rendering all pipework useless, where it could have been re used.
    also, how do these seals withstand an acidic system?
    Sep 2003
    ISRAEL
    66
    4,151
    38
    Quote Originally Posted by hookster View Post
    shaft seals
    valve stems
    sight glasses
    oil pumps
    shraeder valves
    well,
    Shaft seal leaks constantly and not from the O ring.
    Schreader valves do not have o rings apart from the cap.
    On all the other part you have mentioned, the O ring is tighten with bolts to ensure no leak but they still leak if not used correctly.
