    Jul 2017
    Italy
    2
    Acson A5LCX25CR-ACTTA-R Outdoor Unit - Pcb Fault
    Hello there,
    I am in a fairly critical situation ... my two ACSON A5LCX25CR-ACTTA-R (The same outdoor unit branded Daikin: 5SLX25CR) Outdoor Units do not work because the pcb cards inside are broken. I would try to repair them but i'vent pcb circuit diagram. I need your help...thanks in advance.
    Sep 2010
    69
    209
    10
    Re: Acson A5LCX25CR-ACTTA-R Outdoor Unit - Pcb Fault
    Why did they break?
    Brian, retired in Devon.
    Jul 2017
    Italy
    2
    A lizard has burned the first one...the second one give the error e04.
