Results 1 to 14 of 14
Thread: Coolpack
    Mur24's Avatar
    Mur24 Guest
    Coolpack
    Hello all,
    I am an engineer in the far north of Scotland and have come across COOLPACK software to help me with my calculations. I am using the freeware version (1.46) available from the site, but I am having some trouble loading certain Log(p)-h diagrams. Whenever I go to load the diagrams for R407a, and R410a the software goes back to the main screen. Can anyone advise me on a way forward with this situation, or can anyone possibly sketch my diagrams for me?
    Aug 2001
    1,046
    Re: Coolpack
    Dunno what's going wrong for you.
    Two things that you can do:
    1. PM me if you're desperate and let me know what you need. They will save as a JPEG, but as the quality is good in the first place, they can be a large file.
    2. E mail the people in Denmark. In my experience they are very helpful. Address details are in the help file.
    ________
    extreme vaporizer
    Jan 2006
    Croatia
    68
    2,263
    31
    Re: Coolpack
    Hi, Mur24
    Maybe is not bad idea to uninstall and then reinstall CoolPack.
    When you download something you can get some files damaged.
    (My ZIP file of CoolPack is 16.8 MB =17.650.688 bytes)
    (CoolPack exe file is 11.1 MB = 11.702.191 bytes)
    hope this can help or give some idea to you
    Best regards,
    Josip
    Aug 2001
    1,046
    Re: Coolpack
    Yes, a reinstall is a good idea.
    Be sure to uninistall the previous version rather than to install over the top of it.
    Obvious, but.....
    ________
    marijuana strain strawberry cough
    Mar 2006
    China
    83
    Re: Coolpack
    I have using the coolpack for long time.In the module "refrigeration utilities",there is nothing wrong.Mur24 ,maybe well after you reinstall it.
    But a question puzzles me.Except the "refrigeration utilities" module running well,no wrong.others modules run wrong with the error-"unmatched quote marks.in A=stringPos('?,pipe$)" at the beginning.I guess that is the program compile error,but I cant repair it. Do you meet it?
    sagittarius
    Jan 2006
    Croatia
    68
    2,263
    31
    Re: Coolpack
    Hi, sagittarius
    Quote Originally Posted by sagittarius
    sagittarius
    Please, can you be more specific about your problem with CoolPack, (which module, calculation ?) an example maybe
    Best regards,
    Josip
    Mar 2006
    China
    83
    Re: Coolpack
    ok,Josip.
    Coolpack has six modules,refrigeration utilities,cooltools(4) and dynamic.There is the wrong when running the four cooltools program -cycle analysis,design,evaluation,auxiliary.At the beginning of running any program of "CoolTools" there is the prompt"unmatched quote marks.in A=stringPos('?,pipe$)".If I ignore it,click "ok",the program can still run,but I don't know if it is work well.
    Jan 2006
    Croatia
    68
    2,263
    31
    Re: Coolpack
    Hi, sagittarius
    ok,Josip.
    I do not have any prompt when starting with any of cooltools or dynamic. When open any of CoolTools first is EES small window and click to OK. No prompts
    It seems that you have something wrong within your OS or realy damaged CoolTools archive.
    Best regards,
    Josip
    Dec 2002
    South Africa
    83
    41
    Re: Coolpack
    I had a similar problem, I would try to produce a diagram and would end up with the Blue Screen of Death, if I reduced the range with which the calculations were to be made there was no problem. I initially thought that the PC did not have enough memory but in the eventualy scrapped the PC as the CPU became unstable.
    May 2006
    Thailand
    61
    13
    Re: Coolpack
    I think you can download a new coolpack and reinstall is the best ways
    Jun 2006
    58
    42
    Re: Coolpack
    Coolpack is awesome, I can only wish there was a imperial units version for us in the USA.
    maclingt's Avatar
    maclingt Guest
    Re: Coolpack
    Quote Originally Posted by sagittarius View Post
    ok,Josip.
    sagittarius!
    I come from Taiwan, and I have the same problem. But now, I have solved the problem by some tips. The problem is encountered here because the code of CoolPack is written by single character, not double characters. In Taiwan, the character used by Windows is double characters, not single character, so CoolPack produces the message. To solve the problem, just to adjust the setting to language of non-unicode program in control panel-> location and language option. Set the language of non-unicode program to English or Denmark, you will get the solved result.
    puthanate's Avatar
    puthanate Guest
    Re: Coolpack
    I need it also that coolpack. I will
    appreciate if you send it to me.
    puthanate@hotmail.com
    jonbonraki's Avatar
    jonbonraki Guest
    Re: Coolpack
    In the simulation system for two stage cascade system, there is column
    where we have to plug in the value of compressor heat loos factor , is it the same thing as compressor eficinecy and can we calculate exergy analysis using your software??
    there was mention of two different cop in software, how do we calcuate the whole cop of the system...
  1. CoolPack Cycle Input
    By Bones in forum Training
    Last Post: 02-12-2003, 09:18 AM
  2. Replies: 17
    Last Post: 25-08-2003, 09:56 PM
  3. Coolpack
    By Koudijs in forum Training
    Last Post: 03-01-2003, 10:15 PM
