    Jul 2013
    Manchester
    44
    Walls 3 tier ice cream machine
    Hi guys
    I'm not really worked on this kind of unit before. Unit works fine over all however middle tier is only cools to 0 degree while top and bottom -20. Any suggestion. Cheers.
    Sep 2010
    208
    Re: Walls 3 tier ice cream machine
    Can't find a lot on these, am assuming that is some form of Maxivision unit.
    Where is it located?
    What is the ambient temperature where the unit is? (35°C max)
    Condenser clean?
    Correct clearance around unit.
    Is it in warranty?
    Brian, retired in Devon.
    Jul 2013
    Manchester
    44
    Thanks for reply Brian, fridge is in shop. Condenser is clean. I already checked clearance.
    3,360
    Have you defrosted unit?
    Link has some basic instructions
    https://www.wallsrefrigerationsoluti...xivision_1.pdf
    Jul 2013
    Manchester
    44
    I already asked customer to try that as well. I need to re attend next couple of day so looking for suggestions. Thanks.
    Dec 2010
    devon
    837
    Is it a twin comp or one comp they are normally on hc the condensors block up and are prone to waxing capillarys
