    Jul 2013
    Manchester
    37
    Walls 3 tier ice cream machine
    Hi guys
    I'm not really worked on this kind of unit before. Unit works fine over all however middle tier is only cools to 0 degree while top and bottom -20. Any suggestion. Cheers.
    Sep 2010
    69
    209
    10
    Re: Walls 3 tier ice cream machine
    Can't find a lot on these, am assuming that is some form of Maxivision unit.
    Where is it located?
    What is the ambient temperature where the unit is? (35C max)
    Condenser clean?
    Correct clearance around unit.
    Is it in warranty?
    Brian, retired in Devon.
    Jul 2013
    Manchester
    37
    Thanks for reply Brian, fridge is in shop. Condenser is clean. I already checked clearance.
    2,461
    27
    Have you defrosted unit?
    Link has some basic instructions
    https://www.wallsrefrigerationsoluti...xivision_1.pdf
    Jul 2013
    Manchester
    37
    I already asked customer to try that as well. I need to re attend next couple of day so looking for suggestions. Thanks.
    Dec 2010
    devon
    772
    Is it a twin comp or one comp they are normally on hc the condensors block up and are prone to waxing capillarys
