Results 1 to 13 of 13
Thread: corrosion
    Dec 2004
    Australia
    52
    519
    corrosion
    G'day all.
    I live on a coastal area of southern Australia. We install and service a lot of wall mount a/c units of varying brands.
    What I have noticed is a tendency for some of the outdoor units in close proximity of the ocean to show signs of corrosion after a few years.
    Was wondering if any other members have had similar problems and what they might have done to remedy the situation.
    I have already had the suggestion of using a lanolin spray for treating the units and one particular unit that we did repair we ended up using fish oil to treat it.
    Any comments would be appreciated.
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: corrosion
    Coils can be supplied with various surface treatments, like blygold or epoxy paint, able to withstand weather and ambient aggression at various levels of protection.
    Aug 2005
    5,302
    Re: corrosion
    Hi Temprite,
    Here is a link that might provide some useful information.
    http://www.electrofin.com/
    Admittedly, this is a US company but I thought it might provide some ideas on an alternative you might be able to source within Australia.
    Oct 2003
    5,630
    Re: corrosion
    We live also very near the sea and we spray a zinc spray througfh the fins (we use teh spray from Zinga which is more then 99% zinc)
    The heat transfer isn't affected and the zinc will sacrifice itself when corroding.
    Mar 2005
    58
    110
    Re: corrosion
    Quote Originally Posted by Peter_1
    I just had a look at their website www.zinga.be . Does the mermaid come with the spray?
    Dec 2004
    Australia
    52
    519
    Re: corrosion
    Thanks for the replies everyone.
    The coils have been ok since most reputable manufacturers treat them anyway.
    Problem is the casing and more so the feet and base.
    Have some where the feet have nearly collapsed after about 5 years.
    Aug 2005
    5,302
    Re: corrosion
    Here is a link for cold galvanizing spray
    http://www.zrcworldwide.com/p_zrc.asp
    http://www.zrcworldwide.com/pdfs/t_g...pplication.pdf
    The mermaid is quite pretty. Why is she hiding in every picture?
    Oct 2003
    5,630
    Re: corrosion
    Quote Originally Posted by BESC5240
    Bescie, in every 100 boxes, you'll find one.
    It's only a matter of picking the right one.
    Oct 2003
    5,630
    Re: corrosion
    Quote Originally Posted by US Iceman
    That's because we're very shy people USIceman.
    plettenberg bay
    Re: corrosion
    Hi Temprite
    I got first hand experience of the rust and the corrosion that it causes, I use a product called TECTYL, mostly used in the automotive industry to treat the underside of vehicles as a sealant, goes on and sticks like bubblegum to a monkeys backside, last about 2 years in the sun if sprayed nice and thick, speak to your panelbeater about what they use, its oil based just runnier than tar, but same principal
    Dec 2004
    Australia
    52
    519
    Re: corrosion
    Thanks Andre.
    Jun 2006
    British West Indies
    543
    Re: corrosion
    Have a severe salt corrosion problem here, I must have seen almost every coating out there, herestite , bronzglo, adsil, electrofin, sea coat etc.
    What I found works best is to avoid the dissimilar metals in the first place and therefore not worry about the electrolytes.
    The all aluminum spine fin coils (old GE design) currently used by Trane and American Standard will outlast any copper tube aluminum fin coil with a coating.
    Washing an untreated coil on a regular basis extends coil life.
    nevgee's Avatar
    nevgee is offline Veteran Poster I am starting to push the Mods: of RE
    May 2006
    Yorkshire
    72
    417
    Re: corrosion
    FISH OIL? who's pullin who's donga!
  1. Stress Corrosion Cracking in NH3 Vessels
    By US Iceman in forum NH3
    Last Post: 15-02-2008, 06:41 PM
  2. Corrosion for your viewing pleasure :)
    By Tycho in forum Industrial
    Last Post: 09-02-2006, 03:32 AM
  3. Corrosion.
    By romaurie in forum Industrial
    Last Post: 27-11-2005, 10:57 PM
  4. Corrosion...What corrosion?
    By SteveDixey in forum Industrial
    Last Post: 04-08-2003, 05:41 PM
