Results 1 to 21 of 21
    May 2006
    Cwmbran in South Wales
    Any body got any tools lying around?
    If anybody has any installation tools suitable for R410
    please give me a shout.
    Particulary looking for pipe flaring kit, swaging kit, vac pump, recovery machine and scales
    thanks.
    Oct 2001
    Nottingham UK
    5,667
    Re: Any body got any tools lying around?
    Oct 2004
    Scotland
    1,454
    21
    Try E-Bay.... I know someone that got a flareing kit from there for cheap (new).
    Chillin
    and go get a cuppa
    Dec 2004
    Australia
    52
    519
    Quote Originally Posted by cold as ice
    thanks.
    I was told by told at a training session by one of the larger manufacturers of aircon that you could use your existing flare block but you had to allow more pipe to protrude so that a larger flare face was achieved.
    Can anyone else confirm this?
    We were also told existing vac pumps could be used if a solenoid was fitted so that if power was removed from the pump the solenoid would close eliminating the chance of oil entering the system via the vac pump.
    Regards.
    Chris Bexon's Avatar
    Chris Bexon Guest
    you will find you need new service manifold, and nitrogen gauge as test pressure for R410A systems is 42.5 bar (Mitsi) or 38bar (Daikin). Do not miss out on testing. Do not cut costs as cheap equipment could cost bad injury or worse when working at these pressures.
    Chris
    Oct 2001
    Nottingham UK
    5,667
    I find that hard to believe. if you make the flare too large it won't fit inside the flare nut
    Aug 2005
    5,302
    Frank, It might make sense if it is intended for a double flare, but... if this was meant for a single flare I'm not sure I understand how how it would fit either.
    Dec 2004
    Australia
    52
    519
    Quote Originally Posted by frank
    G'day Frank.
    I'm pretty sure that I would know by now if I had made a flare too large.
    I may be mistaken with the details but they definetely said that that we could use our existing flare blocks if we chose to do so.
    Was wondering if anyone else here uses their existing blocks
    Be honest...
    There are still a lot of R22 units being installed in Australia.
    Dec 2004
    Australia
    52
    519
    Just dug some information up from a service manual for use of HFC refrigerants R407C, R410A
    This is a quote straight from the manual.
    "Conventional flaring tools can be used for HFC's if the work process is changed.
    (Change of work process)
    Previously, a pipe extension margin of 0 to 0.5 mm was provided for flaring. For 410A air conditioners, perform pipe flaring with a pipe extension margin of 1.0 to 1.5 mm. (for clutch type only)
    Jigs for pipe extension margin adjustment are available."
    Apr 2006
    Guess
    61
    We started using the old flaring block out of necessity.
    The wholesalers were sold out of the new ones when we looked for them.
    We've been using them for about 18 months now with 410 and have had no problems at all.
    Just make good flares and you'll be fine.
    Think back to your apprentice days "don't over-tighten the punch when flaring as the pipe will need to be able to compensate for the imperfections in the fitting you are connecting to" or words to that effect.
    And "make sure the edges of the flare can touch off the threads on the inside of the flare nut".
    Also we use "leak lock" or similar.
    Has always worked for us.
    If it was easy everyone would do it.
    May 2006
    thanks for the comments guys- much appreciated!
    May 2006
    uk
    thanks.
    Hi, i know they are not tools as such but i still have a 10kg bag of brazing rods and some silver soldier rods that i want to get rid of. im thinking of using ebay but am unsure as they cost a fortune and dont want them to go for pennys
    May 2006
    Nottingham
    72
    163
    Quote Originally Posted by Ireland
    Some images would be good here>
    May 2006
    uk
    Smile Re: Any body got any tools lying around?
    thanks.
    yes i have, can you IM me?
    Jan 2006
    Adelaide , Australia
    192
    Quote Originally Posted by Temprite View Post
    Regards.
    Hey Temprite we meet again or should I call U Glycol man now ? , I guess there are Temprites are still chugging away in the older pubs somewhere . Come to think of it we are all chugging away in this industry . Now its heating up in OZ , everybody wants to be nice to the fridgy .
    Re the 410 questions - Yes I use the same flaring tools I always did but its a good quality Robinair sliding block type. As far as soleniod on vac pumps , havent heard that one . Lets face it how many systems are you going to vac overnight that run on R410 , not too many so just vac it out while you have a breather or several smokes . Many units come with " bleed the pipes " instructions so to vac out is like the holy grail of installation compared to home handyman installer
    Apr 2006
    Guess
    61
    Quote Originally Posted by mick2me View Post
    I'll eventually figure out how to post pictures.
    I'll probably have forgotten about this post by then, though.
    Jan 2006
    192
    Hey Irish click on the " POST REPLY" button instead of writing in the Quick Reply box. You will see there are more icons there just click on the one with the paperclip and select your pics to post. You need to make them small pics , cant remember the size it will tell you somewhere .
    Jan 2006
    192
    Talking Re: Any body got any tools lying around?
    like this one this is the best tool I have lying around hehe
  19. #19
    Apr 2006
    Guess
    61
    I'll give it a try.
    But probably not today....
  20. #20
    Apr 2006
    Guess
    61
    I suppose I managed to do the Avatar so I should be able to sort the thumbnails as well.
  21. #21
    Jan 2006
    192
    Thumbs up Re: Any body got any tools lying around?
    and That Is A Nice Avatar Image
  1. Is anyone selling used air conditioning tools?
    By Samuel12 in forum Air Conditioning
    Last Post: 23-04-2007, 06:09 PM
  2. Tools I need
    By Danny Leblanc in forum Tools and Calculators
    Last Post: 21-11-2006, 08:50 PM
  3. Stainless Steel Filter Body
    By Derek in forum Industrial
    Last Post: 10-04-2003, 06:25 PM
  4. Replies: 5
    Last Post: 16-10-2002, 12:38 AM
