    Jan 2006
    Croatia
    2,127
    Question Help with Danfoss thermostatic valve
    Dear all,
    need your help, because I want to help to my friend...
    The question is ... how to replace damaged valve ...
    Installed is Danfoss thermostatic valve body code 026H1164 is not available
    pilot orifice code for above valve is 067B2790
    thermostatic element code is 067B3310
    and flange set code is 02N1032
    Please help me with equivalent replacement ... if possible non electronic type!
    Thanks for your time and effort.
    Best regards, Josip
    Aug 2014
    69
    422
    Re: Help with Danfoss thermostatic valve
    you can use the ICM valve with ICAd it's an electronic solution or twin up a pair of TE 55 valves.
    What is the systems design conditions and refrigerant type and I'll try to select required valves and any options possible
    Jun 2011
    Australia
    38
    304
    15
    As always, great advice from Mr Glenn
    But sometimes you just want a big valve - like the old days...
    http://ph.parker.com/us/en/thermosta...sporlan-type-w
    Don't them 4 bolt flanges bring some memories!
    Happy tinkering
    Mankind does not know why Coffee make us poop..
    https://m.youtube.com/watch?v=U8Fqyyv16SM
    Jan 2006
    Croatia
    2,127
    Hi Guys,
    many thanks for suggestions ... maybe two pieces of TE55 can solve the problem ...
    TE55 max capacity with R134a is about 220 kW
    TRE80 max capacity with R134a is about 196 kW
    PHT 125-1 at -5/45*C with R134a capacity is 428 kW
    some new moment i.e. info:
    old valve is PHTN 125 (R134a)
    for about 500kW at -3/43*C
    Thermostatic element code 067B3310 (cap 3 m)
    Orifice No.1 code 067B2090
    Valve body code 026H1164
    Velding flanges 1 1/4" code 027N1032
    Hope this will be of some help to find the best equivalent valve ... in general not electronic type
    thanks for your time and effort.
    Best regards, Josip
