    Jun 2017
    Brasil
    5
    GEA Grasso Screw compressors
    Hello everyone,
    I am very happy to be part of this group.
    I need the manuals with disassembly and assembly procedures that have the measures of adjusting the bearing clearances and the measures of the ropes of the rotors and bearings with the tolerances of the GEA Grasso compressors.
    Models: XCR-XC26B-28 and YR-Y26S-28.
    Thank you very much for any help you can give me.
    I extend to everyone.
    3,355
    Re: GEA Grasso Screw compressors
    Souza,
    Check your email for some information.
    3,355
    Jun 2017
    Brasil
    5
    I received the email, thank you.
    I have experience with Mycom compressors, if you have any questions I can help.
    Jun 2017
    Brasil
    5
    3,355
    Souza,
    Thanks for Mycom offer.
    The Vi plates that screw into discharge housing also guide slide valve radially.
    Pay attention to this as they can wear in some machines causing slide valve to come in contact with rotors.
    Housings need special tool for aligning housings in dowel holes.
    It is an expansion dowel that lines up housings, they do not have steel dowel pins like Mycom etc.
    In our region they will lend or hire them when you buy parts, hopefully you can arrange this.
    Parts very expensive for these machines, main bearings not normally replaced, usually pretty good.
    Good luck
    Jun 2017
    Brasil
    5
    OK thank you.
    Do you have a photo of this tool?
