Results 1 to 9 of 9
    Jun 2012
    Pakistan
    44
    High % RLA (about 400%) of compressor motor at start-up
    Dear forum fellows;
    We have TRANE chiller RTWA-216 and one of its motor is having high RLA (about 400% ~ 700 A ) at start-up followed by breaker trip.
    It is worthy to mention that in last season it operated normally .Motor Megger results are also not bad.
    It remained shut-down for many months and the only work that has recently been done is replacement of its cable from main panel.
    Please guide what possible reasons may be and how to troubleshoot it.
    Thanks in advance
    Somerset
    69
    4,758
    Re: High % RLA (about 400%) of compressor motor at start-up
    Hi.
    Is it possible the motor has got Damp?
    Sometimes warming the motor to dry off any Moisture absorbed whilst standing idle, will resolve a tripping motor.
    You say Megga readings are not Bad?
    Care to elaborate?
    Jun 2012
    Pakistan
    44
    Hi.
    Care to elaborate?
    Every time compressor heaters have been run for sufficient time before getting motor started. I wanted to say that motor insulation resistance values /Meggering results are greater than 700 K ohms.
    what are possibilities of mechanical seizure of compressor ?
    ireland
    1,471
    41
    Is there only one compressor having an issue? If not i would look at the new cable...
    Aug 2007
    Adelaide Australia
    70
    567
    You say the mega results are greater than 700 k ohms. What test voltage did you use, 500 or 1000?
    I would normally say anything below 2 megohm would be suspect and as Al suggested the cables could be at fault.
    We are presuming you meggered from the board, if so disconnect at the motor and redo, this should confirm whether it is motor or cable.
    Paul
    Born to fish, forced to work
    3,356
    Assuming a screw compressor
    Was it direction tested after new cable was installed?
    If so how & by whom.
    If not it could be at risk.
    Is it at minimum load?
    3,356
    Single phasing for some reason?
    Apr 2011
    Russia
    139
    15
    Is 700A real amps or reading on display?
    Sep 2003
    ISRAEL
    72
    4,266
    Typical result for a phase lost.
    Check motor protector and contactor. At such high amps, they both need replacing.
