Thread: Tap size
    Jan 2017
    Canada
    13
    Tap size
    Hey guys
    Got a punctured 3/8 inch (outside diameter) sensor well on the chilled water side of a steel pipe.My question is what size drill bit and tap size do i need in order to install a threaded plug ?
    Sep 2010
    70
    209
    10
    Re: Tap size
    It depends on the size of the BSP plug you want.
    Sizes here....
    http://bit.ly/2qG6qXd
    Jan 2017
    Canada
    13
    Re: Tap size
    Plug 1/4 inch (inside diameter) NPT
