    GENGUS's Avatar
    GENGUS Guest
    Sabroe CMO28 mk2 comp unloaders
    Im new to the forum but already read and found some interesting stuff.
    Im currently doing a full overhaul of the above compressor, simple enough until its gets to replacing the seals in the unloader assembly its a nightmare trying to get them together without damaging the new seals. As any member come across this problem and found a solution. Sabroe will build them up for a price
    Jun 2001
    N.Ireland
    1,630
    Re: Sabroe CMO28 mk2 comp unloaders
    Hi Gengus and welcome
    The unloaders I am used to are in their big brother the SMC and are just a metal piston ring.
    If I catch you right the seal in the unloader in a rubber type seal much like a hydralic cylinder.
    In the past with these seals I have used a pipe reducer, and pushed the seal up this and unto the piston, cutting down the reducer to suit the OD that the seal has to go over.
    Kind Regards. Andy
    Dec 2005
    Spain
    61
    Bit of oil
    Vice
    line them up and tighten
    works every time
    :cool: Calvo :cool:
  1. do we need a hermetic or semi hermetic comp.?
    By duraid in forum Fundamentals
    Last Post: 17-04-2007, 05:52 PM
