    Jun 2014
    india
    Discharge pressure of ammonia compressor
    How many psi maximum discharge pressure of reciprocating compressor
    Sep 2010
    70
    209
    10
    Re: Discharge pressure of ammonia compressor
    Make and model number of compressor required before that can be answered.
    Check manufacturers data sheet.
    Sep 2009
    Iran
    483
    12
    it depends on our condensing temp.
    normally every company has own test pressure for that
    2,579
    29
    Maximum discharge pressure if system is designed correctly is 10-15% below lowest relief valve setting on high side of plant.
    Relief valve should have been selected by looking at maximum design pressure on each pressure vessel or component.
    Have a look at reliefs on compressor, high pressure liquid receiver & whatever in on high side.
    What ever is lowest setting based on that you high pressure switch should be minimum 10% below that.
    Sep 2008
    Canada
    775
    12
    Compression ratio should not be greater than 8:1.
    Jun 2014
    india
    Thanks you friends
