Thread: R-22 vs HFC's
19-05-2006, 04:27 AM #1
R-22 vs HFC's
Hi there,
Can anybody help on advising what is the best HFC replacement to R-22 for retail application. Why?
Do you know where I can find Merits and Demerits of R-22 vs. R-404A/R-507/R-407C.
Location is India.
19-05-2006, 06:12 AM #2
Re: R-22 vs HFC's
Originally Posted by Jean
cheers
richard
03-06-2006, 04:19 AM #3
Re: R-22 vs HFC's
Jean, It depends wether you are talking new equipment or retrofitting old equipment. Some large supermarkets and department stores are trending towards R134A and screw compressors in air conditioning and R404a in refrigeration. There are coldstores and supermarkets starting to use CO2. R407C works best in heat exchangers designed to take advantage of its temperature glide. But at the moment R404a is most popular in supermarkets.R507 is not as popular although it is in some ways superior to R404a. This may only be due to the higher availability of R404a and earlier work using R404a by some compressor manufacturers.
03-06-2006, 05:37 AM #4
Re: R-22 vs HFC's
hi dear
this site have the replacement for refrigerants may be it is usefull to you
www.harpintl.com/guide.htm
regards
afeef
03-06-2006, 04:41 PM #5
Re: R-22 vs HFC's
HI ,
R404A is adequate from availabilty point of view and engineers are getting used to the refrg in India. Consider local expertise to handle it.
D.D.KORANNE
INDIA
26-08-2006, 03:59 PM #6
Re: R-22 vs HFC's
HI,
R-404a appears to be the choice except for the handling knowhow and equipments at site inadequancies in India. You need a team of people who really understand intricacies very well ; oil,moisture level, use of right liquid line dryers,deep vacum of system etc.
The refrigerant has moderat discharge end tempeatures and can be used on systems with lower evap temp without dditional; accessories on compressors.
I can help u in selections on my ID ddkoranne@yaho.co.in
D.D.KORANNE
COMPARISON OF HYDROCARBON R-290 AND
By shogun7 in forum RefrigerantsReplies: 17Last Post: 12-01-2009, 07:30 PM -
MACS or Automotive AC
By jg/oz in forum TransportReplies: 85Last Post: 29-05-2006, 05:52 PM -
HFCs for flooded systems?
By garyb in forum RefrigerantsReplies: 15Last Post: 21-04-2006, 10:02 PM -
HFC Gases
By frank in forum Chit Chat & Service StoriesReplies: 0Last Post: 13-10-2005, 09:13 PM -
R404a mineral oil ?
By Richard in forum RefrigerantsReplies: 7Last Post: 24-12-2002, 01:16 AM
