Results 1 to 12 of 12
Thread: Microm controls
    Jul 2001
    Sydney, Australia
    753
    Question Microm controls
    Has anybody had a problem with Microm supermarket case and pack controllers constantly losing their settings or locking up? We use them in Australia, the problem seems to have occurred only in the last couple of years. Microm has supplied "voltage droppers" ( a resistor wired in series with the controller's supply) as they claim that the problem is caused by a higher than design voltage, or fluctuating voltages overheating the internal transformer which in turn causes the chip (located above tranny) to overheat and lose settings.
    Our power supply 240 volts, 50 Hz, with voltage dropper fitted the controls are supplied with 220 volts. I find the voltage idea a bit hard to accept due to the wide number of systems in varying locations and if it is true than why not build more reliable equipment if you know what the problem is! Anybody had any experiences?
    reabottdiehard's Avatar
    reabottdiehard Guest
    Re: Microm controls
    Has anyone heard of a Guardian 636T controller ??
    Jan 2001
    Fife, Scotland.
    66
    1,103
    2
    Jul 2001
    Sydney, Australia
    753
    Re: Microm controls
    I honestly can't believe this control system is still around today...
    ...and she said "give it to me you big fridgie"
    sydney australia
    8
    Re: Microm controls
    If microm wasnt around we wouldnt be able to afford to put tyres on our Porshes now would we Scientist
    Jun 2001
    N.Ireland
    1,630
    Re: Microm controls
    Des,
    the menu looks like the Barker cse controllers used abot 10 years ago?
    Kind Regards Andy
    Jan 2007
    scotland
    159
    Re: Microm controls
    NRC used to fit these to all their packs and cases for tescos they werent as easy as the elm but far more reliable,still alot around used to loose address alot on the pack controllers ithink they were RC622.the case ones the636/635 were prone to loose there time clocks and you would need to reset times or change the boards.
    Jul 2001
    Sydney, Australia
    753
    Re: Microm controls
    Quote Originally Posted by andyrobbo View Post
    pugsley driving a porsche... yeah right!! you guys up north must be on a good wicket, may have to get on that there gravy train...
    Jan 2008
    49
    82
    Re: Microm controls
    Never had many problems with 635/636/1089/1289s, lost their addresses now and again and didn't like water.
    Mar 2008
    44
    10
    Re: Microm controls
    hey there pugsley! thats a central coast name isn't it? i've got a newcastle/gosford/uncle brad name...POOCHIE WOOCHIE
    Jul 2001
    Sydney, Australia
    753
    Re: Microm controls
    in the words of pauline hansen..... "please explain"
    yes it was his name in his junior days given to him on installs
    Somerset
    69
    4,698
    Re: Microm controls
    Quote Originally Posted by 750 Valve View Post
    Hi Guys.
    I don't know if it is relevant.
    But We have from time to time.
    Had some of the Chiller Controllers Loose some of their control settings.
    One of the manufacturers York Technical (Thanks Guys) advised fitting a Power supply filter.
    On the incoming mains.
    They said much the same also adding that the addition of aerials within the area can turn formerly good units into rogue ones!
    And YES fitting the filter has cured the problem!!!
    Cheers Grizzly
  1. Controls
    By shogun7 in forum Technical Discussions
    Last Post: 28-01-2010, 01:26 AM
  2. Johnson Controls HELP
    By MadApprentice in forum Fundamentals
    Last Post: 03-09-2006, 04:32 AM
  3. Controls
    By terrie73 in forum Electrical
    Last Post: 01-04-2005, 08:54 AM
  4. Electronic Controls
    By Bones in forum Supermarket Refrigeration
    Last Post: 04-04-2004, 06:52 AM
  5. Controls
    By 750 Valve in forum Supermarket Refrigeration
    Last Post: 23-02-2004, 07:04 AM
