    May 2016
    usa
    3
    Ac Drain Line Clogged?
    Hi guys, my air condition drain line clogged very frequently, what would be the best way to get rid of this issue? need some good suggestions. Thanks
    Sep 2010
    209
    Re: Ac Drain Line Clogged?
    Does it have a good 'fall' or are there level sections?
    What size is the drain pipe?
    Feb 2015
    India
    43
    Quote Originally Posted by StephenH View Post
    @StephenH Hi! When was the air con.installed? It takes not more than 6 months for dust+fibres to deposit on cooling fins and impeller Vanes. Then these contaminants will be the best brew for fungal and bacterial growth, often slimy, so dust +slime will narrow down the drain hole of the condensed water tray. So unless the tray is removed and cleaned thoroughly, this problem will persist.
    After you have cleaned the fins, Vanes, tray and blown the water drain line, after that once every month decontaminate the fins with a required spray that will take of the growth and won't allow subsequent clogging
    I maintain, everything I have, myself.
    Oct 2007
    jersey channel islands
    187
    We use a product. Called. One shot drain cleaner.
    if you can get it straight into the drain , down thru the drain pan of the indoor unit .
    It chases all the jelly like sludge out of the pipe . How ever it is corrosive , don't get it on your self
    and make sure. No one will come into contact with it as it leaves the building .
    And rinse thru. After .
    Oct 2007
    manchester
    5,707
    45
    really?
