    Jul 2013
    Manchester
    37
    Samsung RS 20 CCSV not defrosting
    Hi guys
    My parents Samsung fridge stop cooling yesterday. I open the panels inside and found coil covered with iced exception of defrost heater at the bottom. Is this common? I manually defrost the coil reassemble panels fridge running over 30 hours and so far no problem. Could somebody let me know what's the possibly. I couldn't test the heater bars and sensors as I didn't had my tester with me. Thanks in advance.
    May 2012
    1,236
    28
    Re: Samsung RS 20 CCSV not defrosting
    All fridges, fridge-freezers ice up at some point.
    As long as it is totally defrosted before switching back on
    It should be ok. Hopefully it was just a lack of defrost due
    to the door being left open or something.
    Let it run, if it ices up again in a week you have an issue, if not
    leave it alone and it should be fine.
    Rob
    Jul 2013
    Manchester
    37
    Thanks for reply Rob, I thou same. Cheers
    Mar 2010
    uk
    37
    2
    Hi ozzie35
    Is it a side by side American wannabe fridge
