    Nov 2013
    uk
    40
    2
    daikin BRC1E51A7 controller totally lockedout
    i have a problem with a dakin BRC1E51A7 controller..
    the buttons have been locked out
    i cant reset it the usual way ie hold cancel button down 4 secs
    it stays locked and nothing changes
    is there another way to reset it?
    Dec 2008
    511
    Re: daikin BRC1E51A7 controller totally lockedout
    Hi sibbits,
    Welcome to the forum.
    Have you tried a power off reset? A call to the Daikin helpdesk may provide the answer or possibly the controller is faulty.
    Oct 2001
    Nottingham UK
    5,127
    42
    From memory, the lock out function can be accessed from the higher engineer level, similar to the BRC1D.
    There is a combination of buttons to be pressed to enter the higher level but at this time of night away from the office....I can't remember :-(
    I'm back on the Pale
    Oct 2007
    manchester
    44
    5,707
    To cancel the key lock mode, continuepressing Menu/Enter button for at leastfour seconds. (During backlight lit)
    (small central round button)
    Oct 2001
    Nottingham UK
    5,127
    42
    Have a look on page 15. https://drive.google.com/file/d/0BwN...ew?usp=sharing
    You want field setting 1c 3:02
    Nov 2013
    uk
    40
    2
    cant seem to access the field setting either, i think the controller is faulty....
    thanks for the help
    Apr 2017
    Shelby County
    36
    10
    Quote Originally Posted by sibbits View Post
    If you can't do it on your own or if you are in doubt, I suggest not to fix it by yourself. Consult or ask help from your dealer instead.
Tags for this Thread
