    Apr 2017
    home
    1
    Hotpoint FF4DK Frost build up in freezer
    Hi All
    Hope you could give me some advice
    I have a hotpoint FF4DK Quadrio fridge/freezer and there is a buildup of ice at the bottom
    of the freezer section ,and not allowing cold air to circulate to the fridge section .
    When turned off and defrosted it will work fine for about 1 week and then there is the ice build up again .
    could this be caused by a faulty defrost heater or electronic damper thermostat
    Thanks in advance
    Mike
    5,127
    42
    Re: Hotpoint FF4DK Frost build up in freezer
    Is the door seal in good repair?
    I'm back on the Pale
