    Apr 2017
    CHINA
    27
    1
    Advantage of closed circuit cooling tower
    Using closed circuit cooling tower will protect the fluid from contamination, maximize system efficiency by reducing fouling and scaling tendencies, reduce system energy cost and maintenenace cost.
    Compared to other heat dissipation system:
    1.vs. cooling tower+heat exchanger
    closed circuit cooling tower is closer to wet bulb temperature and reduced fouling tendency, impove process efficiency
    2. vs. air-cooled system
    the processing temperature of closed circuit cooling tower is 10℃-20℃ lower, and closed circuit cooling tower requires less space and lower energy consumption
    3. vs. one-off water system
    reduces environmental impact, saving up to 95% of the cooling water
    4. reduced installed cost and space required
    Somerset
    63
    4,518
    38
    Re: Advantage of closed circuit cooling tower
    Hi.
    Welcome to the forum!
    Your point is?
    You sound more like a Salesman than a Refrigeration Engineer!
    For what purpose is your post?
    hookster's Avatar
    hookster is offline Veteran Poster I am starting to push the Mods: of RE
    Apr 2007
    Hampshire
    431
    Closed circuit can be very detrimental if the make up water is not pretreated or of sufficient quality. During evaporation, high levels of minerals and salts can build up in the sumps increasing fouling factor dramatically.
    There is no 'true' closed circuit in a cooling tower scenario due to the evaporation of the fluid.
    Locally cooling towers have been reducing in selection due to the high capital cost and high maintenance costs associated with them. The social stigma associated with cooling towers also has a poor reception with planning permissions.
Tags for this Thread
