Thread: Control of Refrigerants
14-09-2007, 08:24 PM #1
Hi: Are any of you recording the usage of refrigerants.
i.e. Supplier, type used, amount, and where.
If so what type of spreed sheet are you using.
Also are any of you aware that if you go to a call and you believe the system has a leak but you are unable to find or repair, you must recover the refrigerant there and then, to stop any further escape, and return and pressure test.
14-09-2007, 08:30 PM #2
Re: Control of Refrigerants
http://www.acrib.org.uk/MG7OLH18285
you should find all you after at our leaders web sitePaul
"KEEP IT COOL"
14-09-2007, 11:09 PM #3
CARE refigerants by BOC
By dogma in forum RefrigerantsReplies: 8Last Post: 23-03-2010, 12:39 PM -
Refrigerants and The Environment
By Josip in forum RefrigerantsReplies: 18Last Post: 18-12-2008, 05:53 PM -
Frick Quantum LX Compressor control panel: Capacity Control Screen
By screw_geek in forum Industrial CompressorsReplies: 17Last Post: 15-06-2008, 06:47 AM -
Control scenario
By Mike Hopkins in forum Technical DiscussionsReplies: 5Last Post: 14-09-2007, 11:25 AM -
New Capacity Control Solution
By embrown in forum New TechnologiesReplies: 19Last Post: 30-12-2003, 01:33 PM
