    May 2006
    Australia
    55
    9
    Carrier 06BA Semihermetic compressors
    Does anyone have a capacity chart for a Carrier 06BA-277-600 semihermetic recip compressors for R22 - The 06B was not a widely sold compressor but I have a couple I want to use but need to confirm capacity
    Aug 2005
    5,302
    Re: Carrier 06BA Semihermetic compressors
    Hi Brads,
    I could not find anything for this model number. However, I might suggest you try contacting Carlyle directly via email.
    http://www.carlylecompressor.com/cor...TI3949,00.html
    This is the contact page for the US headquarters. At the bottom of this page there is an email link for you to send a brief question.
    Hope that helps you.
    Feb 2006
    This compressor was also sold by Copeland (Germany) under the Generic model number D6CN7000. They may have a data table.
    It was primarily a high back pressure R22 compressor designated for use on water chillers.
    I do not have a capacity chart but would advise pumping rate at around 175 m3/hr - a similar compressor with this pumping rate has a duty of about 170,000 watts at nominal chiller conditions.
    Sep 2006
    Mindanao, Phils.
    257
    Please check/provide the exact nameplate details like the serial numbers, etc. Some are rebuilt units and we need to check on its duty. Some are made for aircon application and some for a lower evaporating temperature. Will try to find the list of models/serial nos. that could be use for a particular evaporating temp.
    Oct 2001
    Nottingham UK
    5,668
    I too couldn't find anything for the B series - it's not listed on the Carlyle site.
    here's a couple of links though to the comparison chart and nameplate explanation
    http://www.carlylecompressor.com/Fil...E_AppGuide.pdf
    http://www.carlylecompressor.com/Files/Carlyle_Compressor/Local/US-en/documents/574-917_CrossReferenceGuide.pdf
  1. carrier fault codes
    By richelli in forum Trouble Shooting
    Last Post: 18-06-2010, 07:35 AM
  2. Carrier Compressors main bush
    By malik55 in forum Air Conditioning
    Last Post: 09-03-2007, 02:00 PM
  3. Carrier chiller oil migration
    By lowtech in forum Industrial
    Last Post: 30-04-2006, 04:11 PM
  4. carrier remote
    By superswill in forum Trouble Shooting
    Last Post: 26-04-2006, 09:17 PM
  5. Compressor's volume efficiency
    By John McGru in forum Fundamentals
    Last Post: 16-02-2004, 08:44 AM
