    Mar 2017
    Norway
    3
    Piston compressor overhaul
    Hey, my first post here
    Im going to overhaul a small piston compressor, its for a provition room in the boat im working with. There have been some tec's that changed belt from the electric engine to the compressor and they told me the shaft on the compressor was not feeling good.
    Im wondering since there is no overhaul kit if there is something else then bearings and gaskets that I meybe need?
    The compressor
    - Bock
    - Nr AB24189-001
    Mar 2017
    Norway
    3
    Re: Piston compressor overhaul
    Piston rings, shaft seal?
    Aug 2014
    69
    433
    Suction and discharge valves plus valve plate , and maybe a new crankshaft if the main bearings are suspect. Probably cheaper to get a reconditioned machine than buy all new parts.
    Mar 2017
    Norway
    3
    Okey, thanks
