    Mar 2017
    Saudi arabia
    32
    1
    Sabroe 283 oil lose
    Hello guys
    I am new here and I have one problem in sabroe283 new system oil loss within 1week operation we check oil return resievor and filters oil sepreator its normal and suc, disch pressure also can you anyone suggest me what is possibility
    Sep 2009
    Iran
    61
    484
    13
    Re: Sabroe 283 oil lose
    HI
    It is small reg valve in the second oil separator and after that is a sight glass and then again small reg valve
    Both of them should be open a little to return oil to system again from 2nd one
    If you need more information please let me know
    Also
    did you choose right oil
    Your suction filter should be clean and did you remove cotton from inside of your suction filter
    Aug 2010
    110
    9
    New Compressor Unit? Check the strainer on the oil return control valve. But if it is a new machine perhaps you should call the manufacturer to commission machine. This is not the job for someone who does not know! Safety first!!
