    Feb 2017
    38
    8
    Low pressure switch (another newbie question!)
    Hi everyone
    Another newbie question I'm afraid, hopefully someone can help me understand!
    The low pressure switch... obviously it's on the low suction side of the compressor, I remember that from my course a few months ago. But, is the switch activated when the pressure is too low or too high?
    The engineer in me says if it's saying 'pressure too low in LP side' it must be that there is a blockage in the circuit somewhere. Maybe the expansion valve is stuck (can that happen?) or perhaps the solenoid valve is not activating (it has voltage on it).
    However if it is saying the pressure is too high on the LP side I'm lost... actually now I have written this I'm starting to think it must mean the opposite.
    Can anyone give me a pointer, please?
    Chris
    Dec 2008
    511
    Re: Low pressure switch (another newbie question!)
    The low pressure switch will normally open the circuit in the event of a pressure lower than the set point as it acts as a safety in the event of low pressure.
    You are quite right in that it could be a blockage, the solenoid not lifting or good old fashioned lost its gas charge.
    Feb 2017
    38
    8
    Thanks. That's what I thought, but wanted to check.
    I'll check the solenoid next time I am there.
    Chris
    Sep 2003
    ISRAEL
    65
    4,114
    38
    LPS is widely used to activate capacity control elements such as HGB and compressor's steps to keep certain procedures from freezing.
    When pressure drops below 0C, it closes the contacts.
    Sep 2009
    Iran
    450
    11
    LPS can use for alt of fonction
    Limit for pressure come down from set point
    Used for unloading system sometimes
    Used for starting system sometimes
    Used for starting fan or solinoid valve in blast frizer
    So it depend on how we use it in our system and we disign it
