Results 1 to 9 of 9
    Mar 2010
    Suburb of Moscow
    55
    15
    Comressor GHH-RAND SKK321D
    Hi All Colleagues..
    Anyone can help with the drawings for the this compressor SKK321D 1995 y.
    I have only a spare parts list. If are you know a limit of the shaft's axial play, it will be great..
    Best Regards to All..
    Feb 2011
    Hanoi
    41
    Re: Comressor GHH-RAND SKK321D
    The first time heard about this comp brand and model
    Mar 2010
    Suburb of Moscow
    55
    15
    Hi avico.. I didn't know either until I met it. it old model 1995 y. manufactured.
    2,480
    27
    Scruw,
    From what I see it's an air compressor, is that correct.
    If it's refrigeration maybe post a picture, as it might be something else rebadged.
    With 321 numbers in it, it sound big capacity like a Howden WRV321.
    https://www.howden.com/Brochures/Pro...0WRV%20321.pdf
    Mar 2010
    Suburb of Moscow
    55
    15
    Tnx RANGER.
    it Gas compressor, manufactured be "Schraubenkompressoren Gmbh @ Co..
    Unfortunately, im have not a photo now. May be a little later.
    Regards.
    Jan 2006
    Croatia
    2,121
    23
    Hi, scruw
    welcome to the RE forums ...
    Quote Originally Posted by scruw View Post
    Tnx RANGER.
    Regards.
    each compressor is a gas compressor ... but seems that GHH-RAND does not make refrigeration compressors, but for transportation or some other duty ... as far as I know ... but ... can you tell us which refrigerant is inside of unit.
    Best regards, Josip
    Mar 2010
    Suburb of Moscow
    55
    15
    Hi Josip.
    Tnx for your remark.
    Yes indeed, every screw compressor is gas compressor. But I was keeping in mind to the gas butane, not ammonia or any *****. (Like gas in field gathering on oil production). This compressor be installed at the power station. RAND more dont manufactured these compressors and for this reason it is a rarity.
    Best regards.
    Sep 2006
    netherlands
    38
    I did inspections on 2 off SKK255G (1970) few times in Germany. We always used the Howden clearances for these compressors, they are running on nh3. Axial play: 255-0.125mm max and 321-0.35mm max.
    Mar 2010
    Suburb of Moscow
    55
    15
    Hi Gerben.
    Thank You for Your help..
    Best Regards
