Results 1 to 12 of 12
    Feb 2006
    Mauritius
    15
    Refrigerant Leakage
    Hi all,
    What would be the most accurate way of detecting the slightest leakages in condensor/evaporator coils of R22 units?
    Pravin
    Aug 2005
    5,302
    Re: Refrigerant Leakage
    Electronic leak detector or ultrasonic leak detection would provide the best sensing capabilities I believe.
    Oct 2003
    5,630
    34
    At least pressurise it with OFN till max allwoable pressure, mostly 25 bar (363 psi) and do it the way USICeman said.
    May 2006
    India
    74
    399
    If Aircooled Condenser, Isolate, Remove And Pressurize , Seal It And Dip In Water .
    Feb 2004
    Australia
    286
    21
    I usually use UV leak detector for very small leaks.
    a problem shared is a problem halved
    Dec 2004
    Australia
    52
    519
    Soapy water spray and nitrogen is a good way to pinpoint them after first finding with an electronic.
    Mar 2006
    Merate (LC) - Italy
    2,549
    The electronic leak detectors I came across have not proved to be reliable enough.
    I was able to let it buzz by farting.
    What brands and models are you guys using?
    Feb 2006
    derbyshire
    610
    proper fridge bloke, even farts R22,stick some die in,go on holiday for a week,come back with the lamp and all will be revieled,leak detectors,lost count and interest,use one then check it with bubley.
    Feb 2001
    Tampa Florida
    1,076
    Leak checking a supermarket with 3 miles of pipe and 3,000 lbs of hfc gas is a challenge. Anybody have experience with UV dies and large refrigerant charges? I have heard horror stories about using dies. The cleanup, etc. And the underground, of course. Infra-red detectors seem to be holding up and telling the truth better than heated diode types, in my narrow experience. I also use an ultra-sonic, but I am on a learning curve with it.
    Feb 2006
    derbyshire
    610
    the thread states the coils whitch are accessable though i agree with the usage of other methods also,underfloor leaks etc are a nightmare,thank god there relitivly rare.
    Sep 2005
    Manila, Philippines
    7
    try to use MAPP GAS. flame color will change if you have a leak and you will smell the gas and oil odor of the system. one of the best aside from soft.
    Feb 2005
    Jamaica
    121
    Can I tell u ,speaking of Mapp Gas went on a site once with a senior tech to find a leak on a outdoor condenser,(walk-in-cooler)it was a pin hole found easy with soap and water ,the tech said since it was a small hole,alot had not leaked out(that was his conclusion) so he grabed his torch and started to,in his words "close the pin hole" when he started, I asked "is that safe" hoping he would wake up,his reply was it will be "quick" so i quickly left the roof on my way down the ladder he passed me going down this was after the condenser blew.
    The old gas detectors with the hose MAYBE but a regular MAPP GAS not for me bud
  1. R600 Refrigerant.
    By tonydeith in forum Refrigerants
    Last Post: 21-04-2011, 08:52 AM
  2. CARE refigerants by BOC
    By dogma in forum Refrigerants
    Last Post: 23-03-2010, 12:39 PM
  3. Replies: 2
    Last Post: 16-11-2005, 05:34 PM
  4. Liquid refrigerant and bubles in sightglass
    By aygul in forum Trouble Shooting
    Last Post: 30-08-2003, 09:07 PM
  5. Refrigerant Reclamation
    By herefishy in forum Commercial
    Last Post: 23-07-2003, 08:19 AM
