Results 1 to 11 of 11
Thread: Thermoking
    May 2006
    64
    8
    Thermoking
    Hi Everyone,
    Has anyone any information on charging & gauge testing a Thermoking MB11MAX unit running on R403b Gas, Also to access gauge readings do you have to crack open test points ?.
    Thanks Dave.
    Nov 2001
    Shropshire
    59
    260
    23
    Re: Thermoking
    For R403B the plate should state 3kg.
    The ports do have sheiders (spelling oops)...but you will need to crack the service valves.
    What seems to be the problem.
    May 2006
    64
    8
    Re: Thermoking
    Hi Reeferjon,
    I am the problem,why do I let myself be easily led, I have let a customer talk me into looking after his three fridge lorries after I serviced his car air conditioning (which is my forte). I carry out his service & repair work to his vehicle's so I suppose it makes sense to learn about his fridges the best I can,and I suppose it may lead me to add an extra service to my customers. My main question is about the service points as this is new to me that you have to release the seats to get a reading & I was looking for a guide on low & high pressure readings.
    Thanks Dave.
    Thermoking.kong's Avatar
    Thermoking.kong Guest
    Re: Thermoking
    Hi man thermoking here
    i presume you ment a Md 2 with 403b which has to be quite old
    the service valves have to be cracked open
    the suction pressure and head pressure depend on ambient and load
    but a good guideis about 18psi suction gauge at oc box temp and about 180/200 psi discharge
    Feb 2005
    Hong Kong
    190
    Re: Thermoking
    welcome on board thermoking.kong!
    Guys, just to re-iterate an important point, without bias.
    Like any o.e.m, I expect TK would like to ensure that within the warranty period at least, only authorized sales & service dealers globally service the equipment. This would hold true also for other commercial HVACR brands, Toyota auto, Caterpillar equip,Canon camera etc etc.
    Outside of warranty, yes the customer has freewill to decide and let the best man win! As tkingkong says, freelance agents or customer techs should try to work with local TK agent insofar as possible.
    Aside from ensuring the customer has a perfect working machine, we all should be concerned about the safety aspect of inexperienced ( eg commercial or non - transport) techs working on any transport equip for first time - many of those self powered diesel truck and trailer units of today with "cycle sentry " or Smart Reefer can auto-start at any time based on several demand parameters. You really dont want to have your hands in the wrong place when they start up!
    Transport technician is like a diesel fitter ; a sparky ; a plumber and refrig tech rolled into 1. I am not saying it's more advanced than commercial or residential field but it's sure different.
    Nov 2007
    south florida
    79
    10
    Re: Thermoking
    Quote Originally Posted by thermo prince View Post
    all i can add is why did the tech prior to me mash lines shut & whittle small sticks to keep contactor closed?
    Jan 2003
    East Anglia
    1,160
    Re: Thermoking
    Hello Dave,
    Nice to see another Docwra on the message boards, are you by any chance from Yarmouth.
    Main thing to check with these is the head pressure, especially during the summer months. The condensers tend to get full up with flys and when the units are left running outside in the sun the HP goes through the roof and trips. Just give the condenser a good wash out when you look at it
    Raymond
    11,025
    Re: Thermoking
    ....and no one noticed that he asked his question in May 2006
    REEFER-TEK's Avatar
    REEFER-TEK Guest
    Re: Thermoking
    I know it was posted in spring of 2006 but hey i still want to put my two cents worth in.
    See next quote
    REEFER-TEK's Avatar
    REEFER-TEK Guest
    Re: Thermoking
    I agree with prince on safety first. These units should be service by qualified and trained service technicians. However if you are 3rd party and are familiar with there capabilitys of auot start stop and follow the service procedures, im all for helping in advise.
    I do have publictaed normal operating pressure for tk units.
    Perhaps i will leave an example of one here now
    Normal Discharge Pressure Example
    Refrigerant type R-404A
    Ambient air temperature entering condenser coil 90 F
    Discharge pressure from gauge manifold 305 psig
    Ambient temperature + 30 F = estimated condenser temperature 90 + 30 = 120 F
    Use P/T chart to convert condenser temperature to pressure 310 psig
    Compare estimated pressure to gauge pressure 305/310 Same
    Condenser coil temperature runs about 30 F hotter than ambient air or ambient air runs 30 F cooler than the condenser coil to promote rapid heat exchange.
    Normal Suction Pressure Example
    Return air temperature (box) 20 F
    Suction pressure from gauge manifold 40 psig
    Box temperature - 15 F = estimated evaporator temperature 20 - 15 = 5 F
    Use P/T chart to convert evaporator temperature to pressure 38 psig
    Compare estimated pressure to gauge pressure 40/38 close
    Evaporator coil temperature runs about 15 F colder than return air or return air runs 15 F warmer than the evaporator coil to promote rapid heat exchange.
    I hope this was of help.
    Regards R-T
    Jan 2008
    qatar
    61
    Re: Thermoking
    thanks for ur kind informations
    TRY TO LEARN MORE ABOUT A/C SYSTEM
  1. Thermoking Thermo Guard IV
    By Frozen P in forum Refrigeration Books
    Last Post: 01-09-2010, 10:57 AM
  2. Thermoking Thermoguad IV
    By Frozen P in forum Technical Speculations
    Last Post: 30-08-2010, 02:47 PM
  3. thermoking container manuals
    By jamcool in forum Transport
    Last Post: 18-11-2009, 07:53 PM
  4. Looking for thermoking genset take outs.
    By RaFelix in forum Commercial
    Last Post: 22-07-2008, 02:04 AM
