Thread: dry and wet bulb measure
17-02-2017, 07:39 AM #1
how to measure dry and wet bulb in split air conditioner
17-02-2017, 10:25 AM #2
Re: dry and wet bulb measure
Use wet and dry bulb thermometers.
A physcrometer is the tool you want.Brian - Newton Abbot, Devon, UK
17-02-2017, 10:27 AM #3
Hello Benn,
There are dry and wet bulb thermometers on the market:
With electronic instruments it's not usual, normally there are temperature and humidity sensors, and then you can calculate the wet bulb temperature if you need it.
Regards,
CDuque
