    Jan 2017
    Canada
    Refrigerant recovery with no circulating water through chiller
    Hey Guys
    Need to recover refrigerant charge on a water cooled chiller..Pumps can not be turned on to circulate water through the chiller while am recovering
    What is the safest way or method to recover refrigerant charge with out freezing up any tubes when recovering refrigerant when there's no water circulating through the chiller.Can the push and pull method be applied to recover?
    -Thanks
    38
    Re: Refrigerant recovery with no circulating water through chiller
    Definitely need pumps running, hot wire water pump contactor with a jumper wire
    Jan 2017
    Canada
    Whole system is winterized..got no water in cooling tower and no means to circulate through cooling coils
    ireland
    1,451
    if there is no water in evaporator then you can recover as normal
    Sep 2009
    Iran
    66
    672
    1
    might this can help you
